je vais essayer de vous recopier ici ce qui est present sur les factures. si vous reconnaissez certains éléments je veux bien vos infos
facture 1 :rocker cover chrome cap
rocker cover, polished alloy
r/cover t bars (short) pr, ge89
twin HS2/HS4 carb service kit (34€ c'est peut être des joints ou vis de carbu...? ou un kit pour les réparer...?)
brake pad pin - cooper "s"
boot kit, outer cv (cvk10)
inner cv boot kt - bk71
chrome screen lock strip
deluxe chrome side strip
rocker assy.roller tip, 1.7:1
euro 48
facture 2 :seal, front crankshaft
diff oil seal-mini adu5738
rod change oil seal
comp big end bold 1300
comp big end bolt s/midget
facture 3 :water pump pulley 4.275 dia
full poly car kit late
g/box stabiliser kit
ultimate eng steady kit
head stud, long.
facture 4 :su carb manual
su carb manual
facture 5 :quick release eng.mtg
fr,s/frame rebound buffer (pr)
poly front subframe front mtg
f/subframe solid bush kit (10pc)
poly mini rr shock busk kit 4
poly bump stop kit std front
brake adjusting spanner
quick release eng,mtg
radiator, 4 core. (ARP1171/4R)
facture 6 :suspension tool - metric
flywheel, lightened, std type surcharge
duplex timing gear-lightened
comp stabiliser kit, injection
facture 7 :caliper piston-"s" stainless
mini aeroquip brake hose kit
breather vent, 12mm (chrome)
flywheel puller - heavy duty
system, twin box, c/exit, 1.3/4"euro48
facture 8 :speedo cooper s 200kph
distributor 123 electronic ignition with vac a+
soundproofing kit saloon 70 on
autant dire que je comprend pas grand chose
